cgal-discuss - Re: [cgal-discuss] 2D contour skeletonization
  • To:
  • Cc: "Sebastien Loriot (GeometryFactory)" <>
  • Subject: Re: [cgal-discuss] 2D contour skeletonization
  • Date: Wed, 08 Feb 2012 16:48:59 -0500
On 02/06/2012 03:17 AM, Sebastien Loriot (GeometryFactory) wrote:
If your contours are polygonal, then you can use the
straight skeleton package:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Straight_skeleton_2/Chapter_main.html
hi Sebastien
thanks for your reply. Unfortunately the contours are
defined by B-splines (but fortunately,, my results do
not require scientific rigor).
I managed to convert the contours to bitmaps and
use other free software to extract the skeleton:
http://tech.groups.yahoo.com/group/autotrace/message/1215
the results is not perfect. I might need to come up
with some post-processing to straighten the lines.
Certainly it will be interesting to see autotrace
to use CGAL as the backend some time in the future.
Qianqian
Sebastien.
On 02/04/2012 06:01 PM, Qianqian Fang wrote:
hi list
I have a bunch of tubular 2D contours
(closed outlines). I am wondering if it is
possible to use CGAL to extract the skeletons
of the contours? if yes, can you point me to
some examples?
thank you very much
Qianqian
