- To:
- Subject: Re: [cgal-discuss] Intersecting with Cartesian kerenl
- Date: Mon, 27 Feb 2012 21:17:34 +0100
Read this:
http://www.cgal.org/FAQ.html#inexact_NT
and then use Exact_predicates_exact_constructions_kernel
Sebastien.
On 02/27/2012 06:41 PM, Zohar wrote:
Hi,
Could it be that intersecting two 3D segments that overlap in one edge
(s1[0] == s2[1]):
s1: -1.10431 1.4678 0.379479 -1.10499 1.48276 0.428179
s2: -1.10356 1.45133 0.325848 -1.10431 1.4678 0.379479
with CGAL::Cartesian<double> isn't good enough:
Segment intersection (=s1): -1.10431 1.4678 0.379479 -1.10499 1.48276
0.428179 sqrLen=0.00259594
and I need to use CGAL::Exact_predicates_inexact_constructions_kernel?
Actually I found the problem when I intersected 2 triangles:
Tris sharing 1 vertex,
t1:(-1.11051 1.47118 0.423155 -1.0993 1.4947 0.43336 -1.10431 1.4678
0.379479),
t2:(-1.10431 1.4678 0.379479 -1.09949 1.47281 0.327215 -1.10798 1.42799
0.324362)
and I debugged the problem to intersection_collinear_segments().
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Intersecting-with-Cartesian-kerenl-tp4425392p4425392.html
- [cgal-discuss] Intersecting with Cartesian kerenl, Zohar, 02/27/2012
- Re: [cgal-discuss] Intersecting with Cartesian kerenl, Sebastien Loriot (GeometryFactory), 02/27/2012
- [cgal-discuss] Re: Intersecting with Cartesian kerenl, Zohar, 02/27/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Sebastien Loriot (GeometryFactory), 02/28/2012
- [cgal-discuss] Re: Intersecting with Cartesian kerenl, Zohar, 02/28/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Marc Glisse, 02/28/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Andreas Fabri, 02/28/2012
