- To:
- Subject: Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl
- Date: Tue, 28 Feb 2012 14:43:26 +0100
On 02/28/2012 12:00 PM, Zohar wrote:
I suggest to read the references given in the FAQ about inexact NT,
Another emphasis: The alternative that cgal offers is to use exact_exact
kernel. Intersecting a few thousands of triangles, which takes less than a
second with double, takes more than a minute with an exact kernel. I don't
know Sebastien, it doesn't sound to me a question of robustness anymore.
and in particular this one:
http://www.mpi-inf.mpg.de/departments/d1/ClassroomExamples/
As Mark suggested, if you have a small amount of triangles intersecting, call do_intersect with Exact_predicates_inexact_constructions_kernel and only call the intersect function with Exact_predicates_exact_constructions_kernel.
This strategy is working well and will make your code robust.
The Cartesian_converter is your friend for that:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Class_Cartesian_converter.html
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Intersecting-with-Cartesian-kerenl-tp4425392p4427756.html
- [cgal-discuss] Intersecting with Cartesian kerenl, Zohar, 02/27/2012
- Re: [cgal-discuss] Intersecting with Cartesian kerenl, Sebastien Loriot (GeometryFactory), 02/27/2012
- [cgal-discuss] Re: Intersecting with Cartesian kerenl, Zohar, 02/27/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Sebastien Loriot (GeometryFactory), 02/28/2012
- [cgal-discuss] Re: Intersecting with Cartesian kerenl, Zohar, 02/28/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Marc Glisse, 02/28/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Andreas Fabri, 02/28/2012
