- To:
- Subject: Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl
- Date: Tue, 28 Feb 2012 12:55:08 +0100
On 28/02/2012 12:13, Marc Glisse wrote:
On Mon, 27 Feb 2012, Zohar wrote:
I read this faq already, and I'm aware that the double is less robust,
but I
thought that only for complicated algorithm, I need more than it.
Anything that involves computations (like, say, an addition) is
complicated.
Frankly I
expected the double to be able to intersect two segments with common
edge.
Otherwise I think this should be emphasized (this specific point
regarding
intersection) in the intersection / Cartesian / faq (which is too mild
IMO
on this point).
FAQ: never use Cartesian<double>. If you insist on shooting yourself in
the foot, at least use Simple_cartesian<double> instead.
Anyway I tried the exact_exact and it's terribly slow.
There is a price to pay...
If you only need to check whether 2 objects intersect and not know their
intersection, use a predicate (do_intersect I think) and not a
construction (intersection?), so the Epick kernel might be enough.
Reality is not black and white, so just using the kernel
which makes exact constructions all the time is not always
the best solution.
The mesh generation algorithms sometimes internally use
an exact kernel, although they round results back to
floating point numbers.
andreas
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Intersecting with Cartesian kerenl, Zohar, 02/27/2012
- Re: [cgal-discuss] Intersecting with Cartesian kerenl, Sebastien Loriot (GeometryFactory), 02/27/2012
- [cgal-discuss] Re: Intersecting with Cartesian kerenl, Zohar, 02/27/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Sebastien Loriot (GeometryFactory), 02/28/2012
- [cgal-discuss] Re: Intersecting with Cartesian kerenl, Zohar, 02/28/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Marc Glisse, 02/28/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Andreas Fabri, 02/28/2012
