- To:
- Subject: Re: [cgal-discuss] Polyhedron_3 points / Array of boxes
- Date: Tue, 28 Feb 2012 14:45:08 +0100
How is you hexa-mesh? is it regular or arbitrary? are the boxes axis-aligned?
A screenshot can be helpful too if you have one.
Sebastien.
On 02/28/2012 11:22 AM, Tomislav Maric wrote:
Hi everyone,
what would be the fastest way to compute something like "point in box" for
the points of the Polyhedron_3? I have an array of boxes (extremely large, well over
hundreds of thousands) and a rather large Polyhedron_3 depicting a surface mesh. What I
am aiming at is a fast way of communicating data between an underlying hexahedral mesh
(array of boxes) and the vertices of the Polyhedron..
I've read the chapter on Intersecting sequences of d-Dimensional boxes, and
I'm thinking about this:
1) Create an array of boxes for the Polyhedron_3 facets (triangular mesh)
2) Create an array of boxes for the hex mesh.
3) Compute the intersection test.
4) Sub process: go through every triangle, take the point of the triangle and
find the box (out of the candidates given by the intersection test) within
which the point is located.
This sounds a bit... slow... so any advice is appreciated! :)
Thanks!
Tomislav
- [cgal-discuss] Polyhedron_3 points / Array of boxes, Tomislav Maric, 02/28/2012
- Re: [cgal-discuss] Polyhedron_3 points / Array of boxes, Sebastien Loriot (GeometryFactory), 02/28/2012
- <Possible follow-up(s)>
- Re: [cgal-discuss] Polyhedron_3 points / Array of boxes, Tomislav Maric, 02/28/2012
- Re: [cgal-discuss] Polyhedron_3 points / Array of boxes, Sebastien Loriot (GeometryFactory), 02/29/2012
- Re: [cgal-discuss] Polyhedron_3 points / Array of boxes, Tomislav Maric, 02/29/2012
