cgal-discuss - Re: [cgal-discuss] Polyhedron_3 points / Array of boxes
  • To:
  • Subject: Re: [cgal-discuss] Polyhedron_3 points / Array of boxes
  • Date: Wed, 29 Feb 2012 18:34:37 +0100
I understood that you hexa-mesh an be represented as a kd-tree (http://en.wikipedia.org/wiki/K-d_tree). If this is the case, then
for each point you'll make at most the depth of the tree requests to
find the correct cube.
Sebastien
On 02/28/2012 08:24 PM, Tomislav Maric wrote:
Thank you very much for your help! :)
I have to apologize for asking simple (stupid) questions, but I'm completely
new to CGAL / Comp Geometry.
Not sure if I understood completely what you suggested:
#1) intersection of d-dimensional boxes
#2) k-d tree to position the point in a single box out of those resulting
from #1 based on the in-box simple test
did you have this in mind?
If I do the in-box test for every point against all boxes, the alg will be
very slow. This is why I wanted to narrow down the candidates using the
bounding box for the triangles and a query built up from the whole mesh (at
least it won't be Np * Nc , where Np = number of triangle points, and Nc =
number of voulme mesh cells).
I still don't understand how the k-d tree can help me...
Best regards,
Tomislav
----- Original Message -----
Sent: 02/28/12 07:10 PM
To:
If the boxes are axis aligned, the test is pretty simple, just check
each cartesian coordinates to that of the bounding planes of the box (up
to 6 comparison of double).
The usual approch is then to use a hierarchical data-structure to locate
efficiently the point in the mesh.
If it match your hexa-mesh constraints, in CGAL we have a kd-tree:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching_ref/Class_Kd_tree.htm
HTH,
Sebastien.
On 02/28/2012 03:03 PM, Tomislav Maric wrote:
Well, the mesh is hexahedral and arbitrary. To be sure, by arbitrary I mean
this:
- mesh is a set of cells with boundary patches (lists of labels (IDs) to the
total face list, corresponding to the boundary faces)
- a cell is a list of labels referring to an array of faces
- a face is a list of (counterclockwise counted) labels referring to an array
of points
The mesh connectivity is computed accross the faces: there is an owner-neighbour
relationship which is defined by the cell ID (needed for the communication: which cell
needs to communicate data to which Polyedron_3 point, and vice-versa). The cells with
lower IDs "own" the faces. Each face represents a boundary between max two
cells.
This kind of construction is used as an unstructured mesh used for a Finite
Volume numerical method solution. In its basis, the mesh is consisted of
waterproof (logical: faces are not checked for planarity) polyhedra, but I am
interested only in hexagonal cell geometry, for now.
The boxes are axis alligned, because the cells of the mesh are axis alligned.
Because I need to perform communications between the Polyhedron_3 and this Mesh, I'm
thinking in the direction of an implementation of the BoxIntersectionBox_d concept,
that will inherit from the "cell" class of the Mesh and provide the
requirements needed by the concept. This way, I can re-use the info from the Mesh, and
call CGAL algorithms on it. Either this, or build the Box from the array of points of
each cell (min, max) + cell ID.
Thanks a lot!
Tomislav
Sent: 02/28/12 02:45 PM
To:
How is you hexa-mesh? is it regular or arbitrary? are the boxes
axis-aligned?
A screenshot can be helpful too if you have one.
Sebastien.
On 02/28/2012 11:22 AM, Tomislav Maric wrote:
Hi everyone,
what would be the fastest way to compute something like "point in box" for
the points of the Polyhedron_3? I have an array of boxes (extremely large, well over
hundreds of thousands) and a rather large Polyhedron_3 depicting a surface mesh. What I
am aiming at is a fast way of communicating data between an underlying hexahedral mesh
(array of boxes) and the vertices of the Polyhedron..
I've read the chapter on Intersecting sequences of d-Dimensional boxes, and
I'm thinking about this:
1) Create an array of boxes for the Polyhedron_3 facets (triangular mesh)
2) Create an array of boxes for the hex mesh.
3) Compute the intersection test.
4) Sub process: go through every triangle, take the point of the triangle and
find the box (out of the candidates given by the intersection test) within
which the point is located.
This sounds a bit... slow... so any advice is appreciated! :)
Thanks!
Tomislav
