cgal-discuss - Re: [cgal-discuss] Polyhedron_3 points / Array of boxes
  • To:
  • Subject: Re: [cgal-discuss] Polyhedron_3 points / Array of boxes
  • Date: Wed, 29 Feb 2012 20:39:32 +0100
Thanks a lot for the explanation. I think I get it now, finally. Instead of
using the triangle
geometry/boxes I am dealing directly with orthogonal range searching, in case
I can
build a space partitioning tree from my mesh.  I'll do some reading on this
topic,
since it is completely new to me (I have found a book of DeBerg on
Computational Geometry).
One question: k-d tree in CGAL is based on a static datastructure (CGAL
manual)?
I am asking because there will be mesh refinement done for the hexa-mesh, in
which case,
the structure of the tree should change or I should throw away the tree and
create a completely
new one.. I am counting on having hexa meshes in sizes of milion of cells,
and the code should run
in parallel (task based, OpenMPI, not multithread) on a cluster at some
point.
The refinement is octree based, maybe I can use this data structure as well
for the task of range
searching... I have to read "a bit" first. :)
Thanks again,
Tomislav
> ----- Original Message -----
> From: Sebastien Loriot (GeometryFactory)
> Sent: 02/29/12 06:34 PM
> To:
> I understood that you hexa-mesh an be represented as a kd-tree
> (http://en.wikipedia.org/wiki/K-d_tree). If this is the case, then
> for each point you'll make at most the depth of the tree requests to
> find the correct cube.
> Sebastien
> On 02/28/2012 08:24 PM, Tomislav Maric wrote:
> > Thank you very much for your help! :)
> > I have to apologize for asking simple (stupid) questions, but I'm
> > completely new to CGAL / Comp Geometry.
> > Not sure if I understood completely what you suggested:
> > #1) intersection of d-dimensional boxes
> > #2) k-d tree to position the point in a single box out of those resulting
> > from #1 based on the in-box simple test
> > did you have this in mind?
> > If I do the in-box test for every point against all boxes, the alg will
> > be very slow. This is why I wanted to narrow down the candidates using
> > the bounding box for the triangles and a query built up from the whole
> > mesh (at least it won't be Np * Nc , where Np = number of triangle
> > points, and Nc = number of voulme mesh cells).
> > I still don't understand how the k-d tree can help me...
> > Best regards,
> > Tomislav
> >> Sent: 02/28/12 07:10 PM
> >> To:
> >> If the boxes are axis aligned, the test is pretty simple, just check
> >> each cartesian coordinates to that of the bounding planes of the box (up
> >> to 6 comparison of double).
> >> The usual approch is then to use a hierarchical data-structure to locate
> >> efficiently the point in the mesh.
> >> If it match your hexa-mesh constraints, in CGAL we have a kd-tree:
> >> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching_ref/Class_Kd_tree.htm
> >> HTH,
> >> Sebastien.
> >> On 02/28/2012 03:03 PM, Tomislav Maric wrote:
> >>> Well, the mesh is hexahedral and arbitrary. To be sure, by arbitrary I
> >>> mean this:
> >>> - mesh is a set of cells with boundary patches (lists of labels (IDs)
> >>> to the total face list, corresponding to the boundary faces)
> >>> - a cell is a list of labels referring to an array of faces
> >>> - a face is a list of (counterclockwise counted) labels referring to an
> >>> array of points
> >>> The mesh connectivity is computed accross the faces: there is an
> >>> owner-neighbour relationship which is defined by the cell ID (needed
> >>> for the communication: which cell needs to communicate data to which
> >>> Polyedron_3 point, and vice-versa). The cells with lower IDs "own" the
> >>> faces. Each face represents a boundary between max two cells.
> >>> This kind of construction is used as an unstructured mesh used for a
> >>> Finite Volume numerical method solution. In its basis, the mesh is
> >>> consisted of waterproof (logical: faces are not checked for planarity)
> >>> polyhedra, but I am interested only in hexagonal cell geometry, for now.
> >>> The boxes are axis alligned, because the cells of the mesh are axis
> >>> alligned.
> >>> Because I need to perform communications between the Polyhedron_3 and
> >>> this Mesh, I'm thinking in the direction of an implementation of the
> >>> BoxIntersectionBox_d concept, that will inherit from the "cell" class
> >>> of the Mesh and provide the requirements needed by the concept. This
> >>> way, I can re-use the info from the Mesh, and call CGAL algorithms on
> >>> it. Either this, or build the Box from the array of points of each cell
> >>> (min, max) + cell ID.
> >>> Thanks a lot!
> >>> Tomislav
> >>>> Sent: 02/28/12 02:45 PM
> >>>> To:
> >>>> How is you hexa-mesh? is it regular or arbitrary? are the boxes
> >>>> axis-aligned?
> >>>> A screenshot can be helpful too if you have one.
> >>>> Sebastien.
> >>>> On 02/28/2012 11:22 AM, Tomislav Maric wrote:
> >>>>> Hi everyone,
> >>>>> what would be the fastest way to compute something like "point in
> >>>>> box" for the points of the Polyhedron_3? I have an array of boxes
> >>>>> (extremely large, well over hundreds of thousands) and a rather large
> >>>>> Polyhedron_3 depicting a surface mesh. What I am aiming at is a fast
> >>>>> way of communicating data between an underlying hexahedral mesh
> >>>>> (array of boxes) and the vertices of the Polyhedron..
> >>>>> I've read the chapter on Intersecting sequences of d-Dimensional
> >>>>> boxes, and I'm thinking about this:
> >>>>> 1) Create an array of boxes for the Polyhedron_3 facets (triangular
> >>>>> mesh)
> >>>>> 2) Create an array of boxes for the hex mesh.
> >>>>> 3) Compute the intersection test.
> >>>>> 4) Sub process: go through every triangle, take the point of the
> >>>>> triangle and find the box (out of the candidates given by the
> >>>>> intersection test) within which the point is located.
> >>>>> This sounds a bit... slow... so any advice is appreciated! :)
> >>>>> Thanks!
> >>>>> Tomislav
> >>>> You are currently subscribed to cgal-discuss.
> >>>> To unsubscribe or access the archives, go to
> >>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
