- To:
- Subject: [cgal-discuss] Re: Triangle_2 intersection throws exception
- Date: Tue, 6 Mar 2012 08:24:02 -0800 (PST)
Hi Sebastien
Thanks for the quick repply
I did as you suggest, used a exact_predicates_exact_construnctors kernel
but now I geta warning inside the same function
object_cast inside Lazy_construction_rep::operator() failed. It needs more
else if's (#1)
dynamic type of the Object :
St6vectorIN4CGAL7Point_2INS0_16Simple_cartesianINS0_11Interval_ntILb0EEEEEEESaIS6_EE
which causes my program later on to segfault.
Can you help me?
Miguel
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangle-2-intersection-throws-exception-tp4449736p4450411.html
- [cgal-discuss] Triangle_2 intersection throws exception, mriem, 03/06/2012
- Re: [cgal-discuss] Triangle_2 intersection throws exception, Miguel Oliveira, 03/06/2012
- Re: [cgal-discuss] Triangle_2 intersection throws exception, Sebastien Loriot (GeometryFactory), 03/06/2012
- [cgal-discuss] Re: Triangle_2 intersection throws exception, mriem, 03/06/2012
- Re: [cgal-discuss] Re: Triangle_2 intersection throws exception, Sebastien Loriot (GeometryFactory), 03/06/2012
- Re: [cgal-discuss] Re: Triangle_2 intersection throws exception, Miguel Oliveira, 03/06/2012
- [cgal-discuss] Re: Triangle_2 intersection throws exception, mriem, 03/09/2012
