- To:
- Subject: Re: [cgal-discuss] OFF file reading problem
- Date: Fri, 9 Mar 2012 07:09:37 +0800
> Hi Helmi,
> I am not sure about this, but while I understand that you want to
> create a cube with each face being defined as a square (unlike your
> previous OFF file, the new one can be successfully loaded to Meshlab,
> which means this is a valid OFF file), this causes your file to
> contain duplicate vertices. I am wondering if anybody can clarify
> whether Polyhedron_3 allows duplicate vertices?
> Also, if you receive any error message, it might be helpful to put it here.
> Best regards,
> Nicholas
Some corrections to my previous e-mail:
- Cube should have been cuboid
- "each face being defined as a square" should have been "each vertex
is only incident to one facet"
- [cgal-discuss] OFF file reading problem, Helmi Ben Hmida, 03/08/2012
- Re: [cgal-discuss] OFF file reading problem, Bertrand Pellenard, 03/08/2012
- Re: [cgal-discuss] OFF file reading problem, Helmi Ben Hmida, 03/08/2012
- Re: [cgal-discuss] OFF file reading problem, Nicholas Mario Wardhana, 03/09/2012
- Re: [cgal-discuss] OFF file reading problem, Philipp Moeller, 03/09/2012
- Re: [cgal-discuss] OFF file reading problem, Helmi Ben Hmida, 03/09/2012
- [cgal-discuss] Urgent-OFF file reading problem-Polydehron creation, Helmi Ben Hmida, 03/11/2012
- Re: [cgal-discuss] Urgent-OFF file reading problem-Polydehron creation, Sebastien Loriot (GeometryFactory), 03/26/2012
