- To:
- Cc: Nicholas Mario Wardhana <>, ,
- Subject: Re: [cgal-discuss] OFF file reading problem
- Date: Fri, 09 Mar 2012 10:33:12 +0100
Hello again,
Thanks for your reactions to my mail. I ll try to put u in the big picture. Theses off files are generated from a VRML file containing the set of elements composing a scene.
I´´m creating a small parser taking a vrml file as input and generating a set of off files as output correspondinf to the differents geometries existing inside.
Unfortuantely, there arealso duplicates points, but is it here the problem, since even the corrected OFF resent to me does not correspond to a Polydehron.
PS: The form is not always a cube, but i´m sure it´s a closed one.
PS: Please find one element from the vrml file (if u d like all the vrml file, i can provide it to you)
Best
Thanks in adavance
DEF Oid806_IfcWall_Wand__Mauerziegel_d_17_5_cm__i
Shape
appearance Appearance
material Material
diffuseColor 0.8 0.8 0.8
} # Material
} # Appearance
geometry IndexedFaceSet
ccw TRUE
convex TRUE
solid TRUE
coordIndex
0 1 2 3 -1,
4 5 6 7 -1,
8 9 10 11 -1,
12 13 14 15 -1,
16 17 18 19 -1,
20 21 22 23 -1
] # coordIndex
coord Coordinate
point
19.454456 9.214429 9.195417,
19.454456 9.214429 6,
19.629456 9.214429 6,
19.629456 9.214429 9.195417,
19.629456 13.049429 6,
19.629456 13.049429 8.724564,
19.454456 13.049429 6,
19.454456 13.049429 8.724564,
] # Point
} # Coordinate
normal Normal
vector
-0 -1 0,
-0 -1 0,
-0 -1 0,
-0 -1 0,
1 -0 -0,
1 -0 -0,
1 -0 -0,
1 -0 -0,
0 1 0,
0 1 0,
0 1 0,
0 1 0,
-1 0 0,
-1 0 0,
-1 0 0,
-1 0 0,
0 0 -1,
0 0 -1,
0 0 -1,
0 0 -1,
0 0.121862767485053 0.992546959040671,
] # Vector
} # Normals
} # Geometry
} # Shape
Am 09.03.2012 00:01, schrieb Nicholas Mario Wardhana:
On 9 March 2012 06:49, Helmi Ben Hmida
wrote:
Hello Again,Hi Helmi,
U re right, but, it did not resolve the problem.
Still empty polyderon !!!
Do any one know how o fix this please
This is the correct off
OFF
#Oid806_IfcWall_Wand__Mauerziegel_d_17_5_cm__i.OFF
24 6 24
4 0 1 2 3
4 4 5 6 7
4 8 9 10 11
4 12 13 14 15
4 16 17 18 19
4 20 21 22 23
I am not sure about this, but while I understand that you want to
create a cube with each face being defined as a square (unlike your
previous OFF file, the new one can be successfully loaded to Meshlab,
which means this is a valid OFF file), this causes your file to
contain duplicate vertices. I am wondering if anybody can clarify
whether Polyhedron_3 allows duplicate vertices?
Also, if you receive any error message, it might be helpful to put it here.
Best regards,
Nicholas
- [cgal-discuss] OFF file reading problem, Helmi Ben Hmida, 03/08/2012
- Re: [cgal-discuss] OFF file reading problem, Bertrand Pellenard, 03/08/2012
- Re: [cgal-discuss] OFF file reading problem, Helmi Ben Hmida, 03/08/2012
- Re: [cgal-discuss] OFF file reading problem, Nicholas Mario Wardhana, 03/09/2012
- Re: [cgal-discuss] OFF file reading problem, Philipp Moeller, 03/09/2012
- Re: [cgal-discuss] OFF file reading problem, Helmi Ben Hmida, 03/09/2012
- [cgal-discuss] Urgent-OFF file reading problem-Polydehron creation, Helmi Ben Hmida, 03/11/2012
- Re: [cgal-discuss] Urgent-OFF file reading problem-Polydehron creation, Sebastien Loriot (GeometryFactory), 03/26/2012
