- To: Nicholas Mario Wardhana <>
- Cc:
- Subject: Re: [cgal-discuss] OFF file reading problem
- Date: Fri, 09 Mar 2012 11:10:44 +0100
Hi,
Yes, yes, it will be a closed polyhedron for sure since also vrml does not suport open geometries.
I have tried Bertrand OFF file even u re update, always an empty polyhedron !!!
Am 09.03.2012 10:54, schrieb Nicholas Mario Wardhana:
On 9 March 2012 17:33, Helmi Ben Hmida
wrote:
Hello again,Hi Helmi,
Thanks for your reactions to my mail. I ll try to put u in the big picture.
Theses off files are generated from a VRML file containing the set of
elements composing a scene.
I´´m creating a small parser taking a vrml file as input and generating a
set of off files as output correspondinf to the differents geometries
existing inside.
Unfortuantely, there arealso duplicates points, but is it here the problem,
since even the corrected OFF resent to me does not correspond to a
Polydehron.
PS: The form is not always a cube, but i´m sure it´s a closed one.
PS: Please find one element from the vrml file (if u d like all the vrml
file, i can provide it to you)
Best
Thanks in adavance
DEF Oid806_IfcWall_Wand__Mauerziegel_d_17_5_cm__i
Shape
appearance Appearance
material Material
diffuseColor 0.8 0.8 0.8
} # Material
} # Appearance
geometry IndexedFaceSet
ccw TRUE
convex TRUE
solid TRUE
coordIndex
0 1 2 3 -1,
4 5 6 7 -1,
8 9 10 11 -1,
12 13 14 15 -1,
16 17 18 19 -1,
20 21 22 23 -1
] # coordIndex
coord Coordinate
point
19.454456 9.214429 9.195417,
19.454456 9.214429 6,
19.629456 9.214429 6,
19.629456 9.214429 9.195417,
19.629456 13.049429 6,
19.629456 13.049429 8.724564,
19.454456 13.049429 6,
19.454456 13.049429 8.724564,
] # Point
} # Coordinate
normal Normal
vector
-0 -1 0,
-0 -1 0,
-0 -1 0,
-0 -1 0,
1 -0 -0,
1 -0 -0,
1 -0 -0,
1 -0 -0,
0 1 0,
0 1 0,
0 1 0,
0 1 0,
-1 0 0,
-1 0 0,
-1 0 0,
-1 0 0,
0 0 -1,
0 0 -1,
0 0 -1,
0 0 -1,
0 0.121862767485053 0.992546959040671,
] # Vector
} # Normals
} # Geometry
} # Shape
My apology that it seems like my previous e-mail was sent to your
private inbox, instead of to CGAL mailing list.
Unfortunately I am not familiar enough with VRML to comment on your
VRML script, but if I understand correctly, your "polyhedron" will be
nowhere near being closed. Indeed if you manufacture the object, it
will be closed, but topologically speaking, the existence of boundary
halfedges in the form of rectangles' bounding edges means that your
"polyhedron" is just disconnected open meshes. In other words, your
"polyhedron" is not a polyhedron.
BTW, have you tried Bertrand's OFF file? Although I suppose the second
line should have been "8 6 12" (without the double quotes).
Best regards,
Nicholas
- [cgal-discuss] OFF file reading problem, Helmi Ben Hmida, 03/08/2012
- Re: [cgal-discuss] OFF file reading problem, Bertrand Pellenard, 03/08/2012
- Re: [cgal-discuss] OFF file reading problem, Helmi Ben Hmida, 03/08/2012
- Re: [cgal-discuss] OFF file reading problem, Nicholas Mario Wardhana, 03/09/2012
- Re: [cgal-discuss] OFF file reading problem, Philipp Moeller, 03/09/2012
- Re: [cgal-discuss] OFF file reading problem, Helmi Ben Hmida, 03/09/2012
- [cgal-discuss] Urgent-OFF file reading problem-Polydehron creation, Helmi Ben Hmida, 03/11/2012
- Re: [cgal-discuss] Urgent-OFF file reading problem-Polydehron creation, Sebastien Loriot (GeometryFactory), 03/26/2012
