- To:
- Subject: Re: [cgal-discuss] 3D boolean support
- Date: Fri, 09 Mar 2012 15:24:43 +0100
On 03/09/2012 02:52 PM, Zohar wrote:
Send off files and I'll give it a try.
Hi,
I wrapped CGAL's 3D boolean operations inside a maya plugin to replace
maya's buggy one. There are meshes that CGAL fails to do a boolean operation
on. I was wondering if the package should be stable enough, and if I provide
example of to meshes (.obj or .off) would anyone support the package and
help me resolve it?
Are there any know limitations to the package?There should not be, as long as you provide valid input.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-boolean-support-tp4459502p4459502.html
- [cgal-discuss] 3D boolean support, Zohar, 03/09/2012
- Re: [cgal-discuss] 3D boolean support, Sebastien Loriot (GeometryFactory), 03/09/2012
- [cgal-discuss] Re: 3D boolean support, Zohar, 03/09/2012
- [cgal-discuss] Re: 3D boolean support, Zohar, 03/10/2012
- [cgal-discuss] Re: 3D boolean support, Zohar, 03/12/2012
- Re: [cgal-discuss] Re: 3D boolean support, Sebastien Loriot (GeometryFactory), 03/26/2012
