- To:
- Subject: [cgal-discuss] Polyhedron vertex validity
- Date: Fri, 9 Mar 2012 06:33:47 -0800 (PST)
I'm doing lots of join vertex operations, basically to perform halfedge
collapses, and I ran into a problem while I was traversing the star of a
vertex "u". When I try to access the ID [vertex_handle->id()] or point
[vertex_handle->point()], of one of the vertices which the vertex "u" points
to, my program dies. I'm actually thinking that this is because the topology
becomes invalid or non-2 manifold after a certain collapse.
Is there a way to check if a vertex in a polyhedron is valid, given that I
have the halfedge pointing to it, and the halfedge is valid?
Actually, is it possible for a valid halfedge to point to an invalid
halfedge?
Thanks a lot.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Polyhedron-vertex-validity-tp4459607p4459607.html
- [cgal-discuss] Polyhedron vertex validity, freckles, 03/09/2012
- Re: [cgal-discuss] Polyhedron vertex validity, Sebastien Loriot (GeometryFactory), 03/26/2012
- [cgal-discuss] Re: Polyhedron vertex validity, freckles, 03/26/2012
