cgal-discuss - Re: [cgal-discuss] Polyhedron vertex validity
  • To:
  • Subject: Re: [cgal-discuss] Polyhedron vertex validity
  • Date: Mon, 26 Mar 2012 10:54:10 +0200
On 03/09/2012 03:33 PM, freckles wrote:
I'm doing lots of join vertex operations, basically to perform halfedge
collapses, and I ran into a problem while I was traversing the star of a
vertex "u". When I try to access the ID [vertex_handle->id()] or point
[vertex_handle->point()], of one of the vertices which the vertex "u" points
to, my program dies. I'm actually thinking that this is because the topology
becomes invalid or non-2 manifold after a certain collapse.
Is there a way to check if a vertex in a polyhedron is valid, given that I
have the halfedge pointing to it, and the halfedge is valid?
Actually, is it possible for a valid halfedge to point to an invalid
halfedge?
Thanks a lot.
How do you perform the collapse of edge? If you do it by hand, it might
be that the polyhedron get invalid due to a bad operation.
You can use the is_valid()
bool P.is_valid ( bool verbose = false, int level = 0) const
documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_3.html
to debug this, after each collapse.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Polyhedron-vertex-validity-tp4459607p4459607.html
