cgal-discuss - Re: [cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3
  • To:
  • Subject: Re: [cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3
  • Date: Tue, 13 Mar 2012 11:39:16 +0100
Le lundi 12 mars 2012 23:37:12 Zohar a écrit :
> Maybe there's a better way, but I would construct a AABB tree for the
> polyhedron triangles. The I would find the closest triangle to the query
> point and use Kernel::BoundedSide_2() to determine if the point is on the
> bounded side of the triangle.
BoundedSide_2 is for Kernel::Triangle_2, that is 2D triangles, or more
generally for 2D objects.
For the inside test of point 'p' and a polyhedron 'polyh', you may choose a
random ray with source point 'p', and a random direction, and, using the
AABB tree, query the number of intersections between the polyhedron and that
ray. If the polyhedron is closed, then the point is inside the polyhedron if
and only if the number of intersections between the ray and the polyhedron is
odd.
Note that this method will give you random results if the point is exactly on
the boundary of the polyhedron.
That is important that the direction of the ray is random, because the ray
may
intersect the border of facets of the polyhedron, and the number of
intersections given by the AABB tree will not be the number of intersections
with the polyhedron (because of multiplicity). But the probability of those
degenerate cases, with a random ray, is zero¹.
¹) Given that floating point random generators are not true real random
generators, the probability may be non-zero, but it is really small. To be
sure you can shoot several rays instead of just one.
Laurent Rineau, PhD
