[cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3
- To:
- Subject: [cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3
- Date: Tue, 20 Mar 2012 03:26:36 -0700 (PDT)
I think this linear program is only for illustrating the interface, and not
a practical example. I'm not sure why it's limited only for convex poly.
Anyway you could simply iterate all the faces and check if the point is on
the oriented negative side. But consider the complexity. You'll have to
iterate all the faces. On the other hand using a kdtree costs you
approximately logn. I think Andreas solution is the fastest suggestion so
far:
http://cgal-discuss.949826.n4.nabble.com/Surface-remeshing-using-mesh-generation-td4471479.html
although I didn't have the time to try it yet.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Determine-if-a-point-is-interior-or-exterior-to-a-Polyhedron-3-tp4466730p4488265.html
- [cgal-discuss] Determine if a point is interior or exterior to a Polyhedron_3, sgdimitris, 03/12/2012
- [cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3, Zohar, 03/13/2012
- Re: [cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3, Laurent Rineau (GeometryFactory), 03/13/2012
- [cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3, Zohar, 03/14/2012
- Re: [cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3, Bernd Gärtner, 03/15/2012
- [cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3, Zohar, 03/20/2012
