cgal-discuss - Re: [cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3
  • To: <>
  • Subject: Re: [cgal-discuss] Re: Determine if a point is interior or exterior to a Polyhedron_3
  • Date: Thu, 15 Mar 2012 08:55:23 +0100
If the polyhedron is convex, another option would be to use the CGAL LP solver. You can write the point containment test as a linear program, where each facet defines a linear inequality constraint, see http://www.cgal.org/Manual/latest/doc_html/cgal_manual/QP_solver/Chapter_main.html. There is an example (convex hull containment) performing such a test if the polyhedron is given as a convex hull of vertices, see http://www.cgal.org/Manual/latest/doc_html/cgal_manual/QP_solver/Chapter_main.html#Section_10.5. You could massage this into a program that works with facets.
All the best,
Bernd.
On 3/14/12 2:39 PM, Zohar wrote:
After a few experiments:
http://cgal-discuss.949826.n4.nabble.com/Surface-remeshing-using-mesh-generation-td4471479.html
First the condition should be
plane.oriented_side(p) != CGAL::ON_NEGATIVE_SIDE
since we need oriented plane.
Second we need to remember to test this with all
ftree.all_intersected_primitives() (if the closest point is an edge or a
vertex the returned primitive is random).
Third the oriented side test requires Epec kernel, else the calculation is
wrong. This makes the scheme terribly slow.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Determine-if-a-point-is-interior-or-exterior-to-a-Polyhedron-3-tp4466730p4471850.html
