- To:
- Subject: Re: [cgal-discuss] OFF files-Edges Creation (Triangluation)
- Date: Wed, 14 Mar 2012 23:40:06 +0100
Helmi Ben Hmida
writes:
> Hello every Body,
> I´m trying to weel create the edges in an OFF files respecting this
> template (functional example) in order to convert it to a
> polyderon. To do, an algorithm creating edges has to be automatically
> implemented.
> The standard example sent is this one
> OFF
> 8 10 0
> 19.454456 9.214429 9.195417
> 19.454456 9.214429 6
> 19.629456 9.214429 6
> 19.629456 9.214429 9.195417
> 19.629456 13.049429 6
> 19.629456 13.049429 8.724564
> 19.454456 13.049429 6
> 19.454456 13.049429 8.724564
> 3 0 1 2
> 3 2 3 0
> 3 3 2 4
> 3 4 5 3
> 3 5 4 6
> 3 6 7 5
> 3 7 6 1
> 3 1 0 7
> 3 3 5 7
> 3 7 0 3
> 3 7 0 3
> The problem is with the 4 last edges, is there any relations between
> them to be created automatically by an algorithm, since we have a
> verayty of 3D points number (not always 8)
> Thanks in advance
> H.
It's hard to understand what you want to do. Do you want to read or
write an OFF file from or into a Polyhedron? Polyhedron overloads
operator<< and operator>> for those tasks [1].
If this has absolutely no relevance to your question, I misunderstood
you.
HTH,
Philipp Moeller
GeometryFactory
[1] :
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Section_25.4
- [cgal-discuss] OFF files-Edges Creation (Triangluation), Helmi Ben Hmida, 03/14/2012
- Re: [cgal-discuss] OFF files-Edges Creation (Triangluation), Philipp Moeller, 03/14/2012
- Re: [cgal-discuss] OFF files-Edges Creation (Triangluation), Helmi Ben Hmida, 03/15/2012
- Re: [cgal-discuss] OFF files-Edges Creation (Triangluation), Andreas Fabri, 03/15/2012
- Re: [cgal-discuss] OFF files-Edges Creation (Triangluation), Philipp Moeller, 03/15/2012
