cgal-discuss - Re: [cgal-discuss] OFF files-Edges Creation (Triangluation)
  • To:
  • Cc: Philipp Moeller <>
  • Subject: Re: [cgal-discuss] OFF files-Edges Creation (Triangluation)
  • Date: Thu, 15 Mar 2012 10:36:53 +0100
Hi Philipp,
Thanks for u re replay,
In fact, I want to write an off file onto a Polydehron. Unfortuantely, at the beganning, we don´t have theses OFF files, just we have a VRML and x3d file that we re converting to OFF files. We have made a forst attempt to convert the faces of the VRML to OFF, but, we re getting always an empty Polyhderon, based on Nicholas´s suggestions, it works with a triangulated faces, just with this compbination (see example). I tried to simulate others faces combination, but getting an empty Polyhderon.
The question was, is there some specific restrictions, or algorithm to create theses faces.
Hpepefully that it´s clear
Thanks in advance for u re help, we r blocked here for 2 weeks
Am 14.03.2012 23:40, schrieb Philipp Moeller:
Helmi Ben
Hmida<>
writes:
Hello every Body,
I´m trying to weel create the edges in an OFF files respecting this
template (functional example) in order to convert it to a
polyderon. To do, an algorithm creating edges has to be automatically
implemented.
The standard example sent is this one
OFF
8 10 0
19.454456 9.214429 9.195417
19.454456 9.214429 6
19.629456 9.214429 6
19.629456 9.214429 9.195417
19.629456 13.049429 6
19.629456 13.049429 8.724564
19.454456 13.049429 6
19.454456 13.049429 8.724564
3 0 1 2
3 2 3 0
3 3 2 4
3 4 5 3
3 5 4 6
3 6 7 5
3 7 6 1
3 1 0 7
3 3 5 7
3 7 0 3
3 7 0 3
The problem is with the 4 last edges, is there any relations between
them to be created automatically by an algorithm, since we have a
verayty of 3D points number (not always 8)
Thanks in advance
H.
It's hard to understand what you want to do. Do you want to read or
write an OFF file from or into a Polyhedron? Polyhedron overloads
operator<< and operator>> for those tasks [1].
If this has absolutely no relevance to your question, I misunderstood
you.
HTH,
Philipp Moeller
GeometryFactory
[1] :
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Section_25.4
