cgal-discuss - Re: [cgal-discuss] OFF files-Edges Creation (Triangluation)
  • To:
  • Subject: Re: [cgal-discuss] OFF files-Edges Creation (Triangluation)
  • Date: Thu, 15 Mar 2012 10:59:53 +0100
When the Polyhedron is empty this is a strong indication
that you have either more than 2 triangles adjacent to
the samew edge, or that your triangles are not oriented
consistently. When you have a face i,j,k, then
a neighbor face is j, i, l or i,l,j, or l,j,c, that
is i and j must be oriented in different directions.
andreas
On 15/03/2012 10:36, Helmi Ben Hmida wrote:
Hi Philipp,
Thanks for u re replay,
In fact, I want to write an off file onto a Polydehron. Unfortuantely,
at the beganning, we don´t have theses OFF files, just we have a VRML
and x3d file that we re converting to OFF files. We have made a forst
attempt to convert the faces of the VRML to OFF, but, we re getting
always an empty Polyhderon, based on Nicholas´s suggestions, it works
with a triangulated faces, just with this compbination (see example). I
tried to simulate others faces combination, but getting an empty
Polyhderon.
The question was, is there some specific restrictions, or algorithm to
create theses faces.
Hpepefully that it´s clear
Thanks in advance for u re help, we r blocked here for 2 weeks
Am 14.03.2012 23:40, schrieb Philipp Moeller:
Helmi Ben
Hmida<>
writes:
Hello every Body,
I´m trying to weel create the edges in an OFF files respecting this
template (functional example) in order to convert it to a
polyderon. To do, an algorithm creating edges has to be automatically
implemented.
The standard example sent is this one
OFF
8 10 0
19.454456 9.214429 9.195417
19.454456 9.214429 6
19.629456 9.214429 6
19.629456 9.214429 9.195417
19.629456 13.049429 6
19.629456 13.049429 8.724564
19.454456 13.049429 6
19.454456 13.049429 8.724564
3 0 1 2
3 2 3 0
3 3 2 4
3 4 5 3
3 5 4 6
3 6 7 5
3 7 6 1
3 1 0 7
3 3 5 7
3 7 0 3
3 7 0 3
The problem is with the 4 last edges, is there any relations between
them to be created automatically by an algorithm, since we have a
verayty of 3D points number (not always 8)
Thanks in advance
H.
It's hard to understand what you want to do. Do you want to read or
write an OFF file from or into a Polyhedron? Polyhedron overloads
operator<< and operator>> for those tasks [1].
If this has absolutely no relevance to your question, I misunderstood
you.
HTH,
Philipp Moeller
GeometryFactory
[1] :
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Section_25.4
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
