- To:
- Subject: Re: [cgal-discuss] Question about I/O triangulation with Data
- Date: Thu, 15 Mar 2012 11:51:11 +0100
Hello,
Yes I have look at those pages for 2D but a few things are unclear to me.
It says
"the indices of its vertices and the non combinatorial information (if any) in this face"
what I don't understand is what is the non combinatorial information?
Because if I have a triangulation with say indexes on the vertices and I would like to have that information passed into
cgal through the operator <<(). This seems possible if I interpret the documentation correctly but to me it is not clear how to do it.
If I would known that the vertices are stored in the same order that they are read from the file it would be easy to have a separate
file with the data read into the program. But I don't see it written any where that this is the case and esthetically that solution dosn't look good to me.
mvh
Jonas
Hej Jonas,That makes sense. So, did you have a look at these pages yet?
for 3D:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html
for 2D:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html
(from your mails I couldn't tell whether you are working in 2D or 3D, although I suspect 2D)
On both of these pages at the very end you see that both operator<<() and operator>>() are overloaded in CGAL to act on a triangulation and the format is explicitly explained. Since you already have the full triangulation in some format, I'm guessing it shouldn't be to hard too convert that into 'CGAL-formatting', allowing you to directly read the triangulation into CGAL triangulation object using the extraction operator, operator>>().
Sincerely,
Jakob
https://lists-sop.inria.fr/__wws/info/cgal-discuss <https://lists-sop.inria.fr/wws/info/cgal-discuss>
Hej Jonas,
Maybe a bit silly.....if you have the tessellation already, why use CGAL to recalculate the same tessellation?
Greetsz, Jakob
- [cgal-discuss] Question about I/O triangulation with Data, Jonas Wallin, 03/11/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Philipp Moeller, 03/11/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Jonas Wallin, 03/11/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Jakob van Bethlehem, 03/12/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Jonas Wallin, 03/12/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Jakob van Bethlehem, 03/13/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Jonas Wallin, 03/15/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Philipp Moeller, 03/15/2012
- Re: Re: [cgal-discuss] Question about I/O triangulation with Data, Laurent Rineau (GeometryFactory), 03/15/2012
- Re: Re: [cgal-discuss] Question about I/O triangulation with Data, Jonas Wallin, 03/21/2012
- Re: Re: Re: [cgal-discuss] Question about I/O triangulation with Data, Laurent Rineau (GeometryFactory), 03/21/2012
