- To:
- Subject: Re: Re: [cgal-discuss] Question about I/O triangulation with Data
- Date: Wed, 21 Mar 2012 20:00:42 +0100
Thanks for all help. '
Managed to get it working.
I hadn't understood that the operator << for triangulation where connected with << vertex.
mvh
Jonas Wallin
On Thu, Mar 15, 2012 at 12:30 PM, Laurent Rineau (GeometryFactory) <> wrote:
Le jeudi 15 mars 2012 12:22:00 Philipp Moeller a écrit :
> Jonas Wallin <> writes:As far as I know, the code uses Vertex::operator<< and Vertex::operator>>. If
> > Hello,
> > Yes I have look at those pages for 2D but a few things are unclear to me.
> > It says
> > "the indices of its vertices and the non combinatorial information (if
> > any)
> > in this face"
> > what I don't understand is what is the non combinatorial information?
> The points of the vertex, for example. (As far as I can see this is the
> only things that is currently written to the stream.)
the type Vertex is user-defined, those operator<< and >> could save and load
extra information.
Laurent Rineau, PhD
- [cgal-discuss] Question about I/O triangulation with Data, Jonas Wallin, 03/11/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Philipp Moeller, 03/11/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Jonas Wallin, 03/11/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Jakob van Bethlehem, 03/12/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Jonas Wallin, 03/12/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Jakob van Bethlehem, 03/13/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Jonas Wallin, 03/15/2012
- Re: [cgal-discuss] Question about I/O triangulation with Data, Philipp Moeller, 03/15/2012
- Re: Re: [cgal-discuss] Question about I/O triangulation with Data, Laurent Rineau (GeometryFactory), 03/15/2012
- Re: Re: [cgal-discuss] Question about I/O triangulation with Data, Jonas Wallin, 03/21/2012
- Re: Re: Re: [cgal-discuss] Question about I/O triangulation with Data, Laurent Rineau (GeometryFactory), 03/21/2012
