cgal-discuss - Re: [cgal-discuss] Question about I/O triangulation with Data
  • To:
  • Subject: Re: [cgal-discuss] Question about I/O triangulation with Data
  • Date: Thu, 15 Mar 2012 12:22:00 +0100
Jonas Wallin
writes:
> Hello,
> Yes I have look at those pages for 2D but a few things are unclear to me.
> It says
> "the indices of its vertices and the non combinatorial information (if any)
> in this face"
> what I don't understand is what is the non combinatorial information?
The points of the vertex, for example. (As far as I can see this is the
only things that is currently written to the stream.)
> Because if I have a triangulation with say indexes on the vertices and I
> would like to have that information passed into
> cgal through the operator <<(). This seems possible if I interpret the
> documentation correctly but to me it is not clear how to do it.
Can you just read the file in yourself and use insert to add vertices to
the triangulation?
> If I would known that the vertices are stored in the same order that they
> are read from the file it would be easy to have a separate
> file with the data read into the program. But I don't see it written any
> where that this is the case and esthetically that solution dosn't look good
> to me.
> mvh
> Jonas
> Hej Jonas,
>> That makes sense. So, did you have a look at these pages yet?
>> for 3D:
>> http://www.cgal.org/Manual/**latest/doc_html/cgal_manual/**
>> Triangulation_3_ref/Class_**Triangulation_3.html<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html>
>> for 2D:
>> Triangulation_2_ref/Class_**Triangulation_2.html<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html>
>> (from your mails I couldn't tell whether you are working in 2D or 3D,
>> although I suspect 2D)
>> On both of these pages at the very end you see that both operator<<() and
>> operator>>() are overloaded in CGAL to act on a triangulation and the
>> format is explicitly explained. Since you already have the full
>> triangulation in some format, I'm guessing it shouldn't be to hard too
>> convert that into 'CGAL-formatting', allowing you to directly read the
>> triangulation into CGAL triangulation object using the extraction operator,
>> operator>>().
>> Sincerely,
>> Jakob
>>> Hej Jonas,
>>> Maybe a bit silly.....if you have the tessellation already, why use
>>> CGAL to recalculate the same tessellation?
>>> Greetsz, Jakob
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/__**wws/info/cgal-discuss<https://lists-sop.inria.fr/__wws/info/cgal-discuss><
>>> https://lists-sop.inria.fr/**wws/info/cgal-discuss<https://lists-sop.inria.fr/wws/info/cgal-discuss>
Philipp Moeller
GeometryFactory
