Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
- To:
- Subject: Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
- Date: Fri, 16 Mar 2012 00:18:39 +0300
I didn't find the lib file there so I will try to repair the VS 10 and let you know the results
On 15 March 2012 12:29, Laurent Rineau (GeometryFactory) <> wrote:
Le jeudi 15 mars 2012 10:20:00 Sweety Pie a écrit :
> LINK : fatal error LNK1104: cannot open file 'MSVCRTD.libDo you have that file in C:\Program Files (x86)\Microsoft Visual Studio
10.0\VC\lib\msvcrtd.lib ? If no, then you will probably have to
reinstall/repair MSVC 2010.
If yes, then open devenv.exe, and make sure you have "$(VCInstallDir)lib" in
"Tools | Options | Project and Solution | VC++ Directories | Show directories
for: Library files".
Laurent Rineau, PhD
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, (continued)
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Andreas Fabri, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/14/2012
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/16/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Andreas Fabri, 03/16/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/16/2012
