cgal-discuss - [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library
  • To: , , , ,
  • Subject: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library
  • Date: Fri, 16 Mar 2012 11:48:14 +0100
The CGAL Open Source Project is pleased to announce the release 4.0
of CGAL, the Computational Geometry Algorithms Library.
CGAL 4.0 differs from version 3.x in licensing, and in functionality.
We increased the major number of the CGAL version to '4' in order to
reflect this license change.
The license has been changed from LGPLv2.1 to LGPLv3+
(GNU Lesser General Public License) and from QPL (Q Public License v1.0)
to GPLv3+ (GNU Public License), depending on each package.
These license changes are not fundamental, that is, the licenses
are similar in their spirit, and the change reflects the fact
that the QPL has become marginal, since it had been introduced
and later abandoned for Qt.
Major changes in this release include the following:
o Linear Cell Complex (new package)
This package implements linear cell complexes, objects in
dimension d with linear geometry. They are based on the
Combinatorial Map where points are associated to vertices.
o 2D Voronoi Diagram Adaptor (temporarily removed)
As the copyright holder of this package has not granted
the right to switch from QPL to GPL, this package is
temporarily removed from the distribution.
o 2D and 3D Alpha Shapes
Make it more robust for the Exact_predicates_inexact_constructions_kernel
o AABB Tree, Spatial Searching
Queries on these data structures are now multi-thread safe.
o Surface Reconstruction from Point Sets,
Planar Parameterization of Triangulated Surface Meshes,
Approximation of Ridges and Umbilics on Triangulated Surface Meshes, and
Estimation of Local Differential Properties of Point-Sampled Surfaces
If you use the Eigen library (http://eigen.tuxfamily.org),
these packages no longer need Taucs, Lapack or Blas.
See http://www.cgal.org/releases.html for a complete list of changes.
The CGAL project is a collaborative effort to develop a robust,
easy-to-use, and efficient C++ software library of geometric data
structures and algorithms, like
- triangulations (2D constrained triangulations and Delaunay
triangulations in 2D and 3D, periodic triangulations),
- Voronoi diagrams (for 2D and 3D points, 2D additively weighted
Voronoi diagrams, and segment Voronoi diagrams),
- Boolean operations on polygons and polyhedra,
- regularized Boolean operations on polygons with curved arcs
- arrangements of curves,
- mesh generation (2D, 3D and surface mesh generation,
surface mesh subdivision and parametrization),
- alpha shapes (in 2D and 3D),
- convex hull algorithms (in 2D, 3D and dD),
- operations on polygons (straight skeleton and offset polygon),
- search structures (kd trees for nearest neighbor search, and
range and segment trees),
- interpolation (natural neighbor interpolation and placement of
streamlines),
- optimization algorithms (smallest enclosing sphere of points or
spheres, smallest enclosing ellipsoid of points, principal
component analysis),
- kinetic data structures
Some modules are distributed under the terms of the LGPL Open Source
license (GNU Lesser General Public License v3 or later versions).
Most modules are distributed under the terms of the GPL Open Source
license (GNU General Public License v3 or later versions).
If your intended usage does not meet the criteria of the
aforementioned licenses, a commercial license can be purchased from
GeometryFactory (http://www.geometryfactory.com/).
For further information and for downloading the library and its
documentation, please visit the CGAL web site: http://www.cgal.org/
Laurent Rineau, PhD
