Re: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library
- Date: Mon, 19 Mar 2012 01:13:09 +0100
Hi,
>> Debian packages for CGAL 4.0 are now available as well. Simply add
>> deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian squeeze main
>> deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian squeeze main
>> deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian wheezy main
>> deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian wheezy main
> Where would I find the public key, used to verify the repository?
> Thanks for the packages.
The public key can be downloaded from here
http://www.joachim-reichel.de/aboutme/pgpkey/0x153ff940.asc
or from most key servers. If you install the debian-keyring package you
can find the key also in /usr/share/keyrings/debian-maintainers.gpg.
Joachim
- [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library, Laurent Rineau (GeometryFactory), 03/16/2012
- Re: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library, Joachim Reichel, 03/16/2012
- Re: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library, W Randolph Franklin, 03/19/2012
- Re: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library, Joachim Reichel, 03/19/2012
- [cgal-discuss] CGAL 4.0 eigen problem, W Randolph Franklin, 03/26/2012
- Re: [cgal-discuss] CGAL 4.0 eigen problem, Sebastien Loriot (GeometryFactory), 03/26/2012
