Re: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library
- Date: Fri, 16 Mar 2012 18:22:55 +0100
Hi,
On 03/16/2012 11:48 AM, Laurent Rineau (GeometryFactory) wrote:
> The CGAL Open Source Project is pleased to announce the release 4.0
> of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 4.0 are now available as well. Simply add
deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian squeeze main
deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian squeeze main
deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian wheezy main
deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian wheezy main
to /etc/apt/sources list (you only need the pair of lines corresponding
to the release you are using). For sid, packages are available from the
official Debian repository. The packages are called libcgal9,
libcgal-dev, libcgal-demo, and libcgal-ipelets. (Note: the repository
component has changed from "non-free" to "main".)
In case you want to download the packages manually, have a look at
ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian/pool/main/c/cgal/
See also http://www.cgal.org/FAQ.html#debian_packages .
Joachim
- [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library, Laurent Rineau (GeometryFactory), 03/16/2012
- Re: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library, Joachim Reichel, 03/16/2012
- Re: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library, W Randolph Franklin, 03/19/2012
- Re: [cgal-discuss] CGAL 4.0 Released, Computational Geometry Algorithms Library, Joachim Reichel, 03/19/2012
- [cgal-discuss] CGAL 4.0 eigen problem, W Randolph Franklin, 03/26/2012
- Re: [cgal-discuss] CGAL 4.0 eigen problem, Sebastien Loriot (GeometryFactory), 03/26/2012
