- To:
- Subject: Re: [cgal-discuss] Constraned Triangulation 2 problem with remove vertice
- Date: Tue, 20 Mar 2012 14:14:28 +0100
> At some point in my program, I need to remove vertices. I use
> dt.remove(fh->vertex(li))
Are you sure that the face handle is valid? Removing vertices might
invalidate face handles.
> Attached are two images.
I can not read any numbers - can you send images with larger resolution?
Also it is not clear to me, which edges belong to the triangulation.
> Note that vertice 82 is inside a triangle ?? this should not happen.
After inserting or after deleting?
PGP key: http://www.winniehell.de/0xA8FE4F09.pub.asc
signature.asc
Description: OpenPGP digital signature
- [cgal-discuss] Constraned Triangulation 2 problem with remove vertice, mriem, 03/19/2012
- Re: [cgal-discuss] Constraned Triangulation 2 problem with remove vertice, Winnie Hellmann, 03/20/2012
- [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice, mriem, 03/20/2012
- Re: [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice, Winnie Hellmann, 03/20/2012
- RE: [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice, Miguel Armando Riem de Oliveira, 03/20/2012
- Re: [cgal-discuss] Constraned Triangulation 2 problem with remove vertice, Sebastien Loriot (GeometryFactory), 03/20/2012
- Re: [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice, Sebastien Loriot (GeometryFactory), 03/20/2012
