- To: <>
- Subject: RE: [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice
- Date: Tue, 20 Mar 2012 14:54:03 -0000
- Organization: UA
Hi Winnie
Do you think I should test the validity of the face
CDT::Face_handle fh;
fh->is_valid();
or you think I should assess the validity of the whole triangulation
CDT cdt;
cdt->is_valid();
Because I used the previous and at some point it crashes in an assertion.
Perhaps as you say somehow I brake the TDS at some point.
One question about the handles (Face_handle and Vertex_handle)
Are they copy constructable? Can I put them in an STL container like
std::vector<Face_handle>
Also, in which occasions are handles invalidated?
Obviously when the TDS changes somehow, which includes insertion/removal of
vertices.
But does TDS change when I add/remove constraints?
Thanks for the help
Miguel
-----Original Message-----
[mailto:]
On Behalf Of
Winnie Hellmann
Sent: Tuesday, March 20, 2012 2:44 PM
To:
Subject: Re: [cgal-discuss] Re: Constraned Triangulation 2 problem with
remove vertice
> The triangulation is invalid as it is ...
For me, it looks like the triangulation data structure is broken. Have
you checked that fh is valid as I said. Or do you maybe use a face
handle which has been invalidated by removing a vertex?
PGP key: http://www.winniehell.de/0xA8FE4F09.pub.asc
- [cgal-discuss] Constraned Triangulation 2 problem with remove vertice, mriem, 03/19/2012
- Re: [cgal-discuss] Constraned Triangulation 2 problem with remove vertice, Winnie Hellmann, 03/20/2012
- [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice, mriem, 03/20/2012
- Re: [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice, Winnie Hellmann, 03/20/2012
- RE: [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice, Miguel Armando Riem de Oliveira, 03/20/2012
- Re: [cgal-discuss] Constraned Triangulation 2 problem with remove vertice, Sebastien Loriot (GeometryFactory), 03/20/2012
- Re: [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice, Sebastien Loriot (GeometryFactory), 03/20/2012
