cgal-discuss - [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice
  • To:
  • Subject: [cgal-discuss] Re: Constraned Triangulation 2 problem with remove vertice
  • Date: Tue, 20 Mar 2012 07:14:07 -0700 (PDT)
Hi Winnie
Sorry. I've uploaded the images with higher resolution
So this is the first image
http://cgal-discuss.949826.n4.nabble.com/file/n4488936/img1.png
The triangulation is shown by the blue or red lines.
The green triangle is one that I am going to insert in the future, so it is
not a part of the triangulation.
Vertices are indicated with the number near them.
Since this is a Contrained triangulation, constraints are indicated by the
red large patches in the middle of each edge. A large red patch indicates
the edge is constrained.
My problem is that I wan to insert the green triangle, but I want to be sure
it will be a triangle in the triangulation (as opposed to just inserting the
3 vertices of that triangle)
To be sure that the green triangle will be a triangle in the mesh, I must
remove vertex number 9 (the one that is inside the triangle, but now I think
you will be able to see the numbers)
When I remove vertex 9 (note I did not insert green triangle yet), this is
the state of the mesh after removal
http://cgal-discuss.949826.n4.nabble.com/file/n4488936/img2.png
Vertex 9 disappeared as expected, but vertex 82 (to the right of the green
triangle) is inside face with vertices 1046, 1048 and 83.
The triangulation is invalid as it is ...
I wonder if it has to do with my mesh being a heavily constrained mesh
(almost all edges are constrained) and the fill_hole method after deleting
the vertex does some error due to this.
I should not be aproximations since Im using exact kernels
Thanks for the help
Miguel
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Constraned-Triangulation-2-problem-with-remove-vertice-tp4485130p4488936.html
