- To:
- Subject: Re: [cgal-discuss] how eliminate some tetrahedrons?
- Date: Wed, 21 Mar 2012 16:51:36 +0100
One way to do it is to instantiate the triangulation with a base cell class of type Triangulation_cell_base_with_info_3 that supports additionnal information stored in the triangulation cells. Then you may add a boolean in each cell to mark tetrahedra inside/outside the domain of interest. Le 21/03/12 12:32, Juan Carlos Lopez Alfonso a écrit : Hi all, I have a question related with a delaunay triangulation. I have triangulated a set of points and I want to know how I can remove some tetrahedrons of this triangulation. For example I have the following triangulation: Delaunay T; and I have iterated over all tetrahedrons and when one edge of one of them is more than a defined threshold, I want to eliminate this tetraheron of T. The idea is eliminate external tetrahedrons in order to obtain a nonconvex domain triangulation. I need eliminate this tetrahedrons of T, because I need to iterate the set of tetrahedrons which are incident in the infinite vertex. Some thing like this: T.incident_cells(T.infinite_vertex(), std::back_inserter(infinite_cells)); Is there any form to eliminate tetrahedrons of T? Best regards Juan Carlos -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] how eliminate some tetrahedrons?, Juan Carlos Lopez Alfonso, 03/21/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Mariette Yvinec, 03/21/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Juan Carlos Lopez Alfonso, 03/21/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Sebastien Loriot (GeometryFactory), 03/22/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Juan Carlos Lopez Alfonso, 03/23/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Sebastien Loriot (GeometryFactory), 03/23/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Guillaume Damiand, 03/23/2012
