- To:
- Subject: Re: [cgal-discuss] how eliminate some tetrahedrons?
- Date: Thu, 22 Mar 2012 22:54:14 +0100
On 03/21/2012 05:04 PM, Juan Carlos Lopez Alfonso wrote:
Hi,Maybe removing one on the two points that are too close from the triangulation?
thank you for your answer, but this solution don't solve my problem,
because I need to iterate the set of tetrahedrons which are incident
in the infinite vertex. Some thing like this:
T.incident_cells(T.infinite_vertex(), std::back_inserter(infinite_cells));
and for this reason I need to eliminate some of them of the
triangulation in order to have other external tetrahedrons.
any other idea?
Sebastien
Best Regards
Juan Carlos
On Wed, Mar 21, 2012 at 4:51 PM, Mariette Yvinec
wrote:
One way to do it
is to instantiate the triangulation with
a base cell class of type Triangulation_cell_base_with_info_3
that supports additionnal information stored in the triangulation cells.
Then you may add a boolean in each cell
to mark tetrahedra inside/outside the domain of interest.
Le 21/03/12 12:32, Juan Carlos Lopez Alfonso a écrit :
Hi all,
I have a question related with a delaunay triangulation. I have
triangulated a set of points and I want to know how I can remove some
tetrahedrons of this triangulation.
For example I have the following triangulation: Delaunay T;
and I have iterated over all tetrahedrons and when one edge of one of
them is more than a defined threshold, I want to eliminate this
tetraheron of T. The idea is eliminate external tetrahedrons in order
to obtain a nonconvex domain triangulation. I need eliminate this
tetrahedrons of T, because I need to iterate the set of tetrahedrons
which are incident in the infinite vertex. Some thing like this:
Is there any form to eliminate tetrahedrons of T?
Best regards
Juan Carlos
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
- [cgal-discuss] how eliminate some tetrahedrons?, Juan Carlos Lopez Alfonso, 03/21/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Mariette Yvinec, 03/21/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Juan Carlos Lopez Alfonso, 03/21/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Sebastien Loriot (GeometryFactory), 03/22/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Juan Carlos Lopez Alfonso, 03/23/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Sebastien Loriot (GeometryFactory), 03/23/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Guillaume Damiand, 03/23/2012
