- To:
- Subject: Re: [cgal-discuss] how eliminate some tetrahedrons?
- Date: Fri, 23 Mar 2012 15:26:25 +0100
Hi,
Thank you for your answer. But about this, I can't remove points, I am
looking for a Triangulation function to remove tetrahedrons. Is there
any form to do that?
Regards
Juan Carlos
On Thu, Mar 22, 2012 at 10:54 PM, Sebastien Loriot (GeometryFactory)
wrote:
> On 03/21/2012 05:04 PM, Juan Carlos Lopez Alfonso wrote:
>> Hi,
>> thank you for your answer, but this solution don't solve my problem,
>> because I need to iterate the set of tetrahedrons which are incident
>> in the infinite vertex. Some thing like this:
>> T.incident_cells(T.infinite_vertex(), std::back_inserter(infinite_cells));
>> and for this reason I need to eliminate some of them of the
>> triangulation in order to have other external tetrahedrons.
>> any other idea?
> Maybe removing one on the two points that are too close from the
> triangulation?
> Sebastien
>> Best Regards
>> Juan Carlos
>> On Wed, Mar 21, 2012 at 4:51 PM, Mariette Yvinec
>> wrote:
>>> One way to do it
>>> is to instantiate the triangulation with
>>> a base cell class of type Triangulation_cell_base_with_info_3
>>> that supports additionnal information stored in the triangulation cells.
>>> Then you may add a boolean in each cell
>>> to mark tetrahedra inside/outside the domain of interest.
>>> Le 21/03/12 12:32, Juan Carlos Lopez Alfonso a écrit :
>>> Hi all,
>>> I have a question related with a delaunay triangulation. I have
>>> triangulated a set of points and I want to know how I can remove some
>>> tetrahedrons of this triangulation.
>>> For example I have the following triangulation: Delaunay T;
>>> and I have iterated over all tetrahedrons and when one edge of one of
>>> them is more than a defined threshold, I want to eliminate this
>>> tetraheron of T. The idea is eliminate external tetrahedrons in order
>>> to obtain a nonconvex domain triangulation. I need eliminate this
>>> tetrahedrons of T, because I need to iterate the set of tetrahedrons
>>> which are incident in the infinite vertex. Some thing like this:
>>> Is there any form to eliminate tetrahedrons of T?
>>> Best regards
>>> Juan Carlos
>>> Mariette Yvinec
>>> Geometrica project team
>>> INRIA Sophia-Antipolis
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] how eliminate some tetrahedrons?, Juan Carlos Lopez Alfonso, 03/21/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Mariette Yvinec, 03/21/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Juan Carlos Lopez Alfonso, 03/21/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Sebastien Loriot (GeometryFactory), 03/22/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Juan Carlos Lopez Alfonso, 03/23/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Sebastien Loriot (GeometryFactory), 03/23/2012
- Re: [cgal-discuss] how eliminate some tetrahedrons?, Guillaume Damiand, 03/23/2012
