- To:
- Subject: Re: [cgal-discuss] Modified Butterfly
- Date: Mon, 26 Mar 2012 10:49:21 +0200
On 03/08/2012 06:38 PM, Wester wrote:
Hi,Sorry for the late answer.
I'm absolutely new to CGAL. I want to use CGAL to model optical surfaces. I
have to subdivide the surfaces in such a way that the original vertices, which
are ray positions, a preserved. That means I need an interpolating subdivision
scheme. As far as I could figure out, there is no such scheme implemented in
CGAL. Does anybody know of an implementation of the modified butterfly
subdivision using CGAL?
I would be very appreciative for any help.
Regards
Rolf Wester
The framework in CGAL is generic and you should be able to implement
this new subdivion scheme with it (but nothing already exists).
See for example this example:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Subdivision_method_3/Chapter_main.html#Section_51.8
Sebastien.
- [cgal-discuss] Modified Butterfly, Wester, 03/08/2012
- Re: [cgal-discuss] Modified Butterfly, Sebastien Loriot (GeometryFactory), 03/26/2012
