Re: [cgal-discuss] Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?
- To:
- Subject: Re: [cgal-discuss] Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?
- Date: Mon, 26 Mar 2012 11:51:26 +0200
freckles
writes:
> I am facing this problem with Orthogonal_k_neighbor_search::Tree, when even
> using the same typedefs as the simple example on
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html
> , I am unable to compile.
Can you provide a minimal example to reproduce this? Including the
compiler you used and which CGAL version. Which example is the simple
example? The only time `simple` appears on the page is in
`Simple_cartesian` ;)
> I get a "cannot access private member declared in class CGAL::Kd_tree"
> compile error and this makes *no* sense at all, because it is clearly
> declared public in the Kd_tree class.
> Is there any way this could ever occur?
Old versions of gcc used to ignore access specifiers of typedefs. But
the code passes our test-suite with new compilers, so this shouldn't be
an issue.
> Thanks :)
Philipp Moeller
GeometryFactory
- [cgal-discuss] Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, freckles, 03/26/2012
- Re: [cgal-discuss] Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, Philipp Moeller, 03/26/2012
- [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, freckles, 03/27/2012
- Re: [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, Sebastien Loriot (GeometryFactory), 03/27/2012
- Re: [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, Philipp Moeller, 03/27/2012
