Re: [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?
- To:
- Subject: Re: [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?
- Date: Tue, 27 Mar 2012 09:34:04 +0200
"Sebastien Loriot (GeometryFactory)"
writes:
> On 03/27/2012 04:01 AM, freckles wrote:
>> Well, that's the weird thing. It's not reproducable in a minimal example as
>> it has worked before, it's just when a Kd_tree was added as a member object
>> in a *particular* class, it gave that compile error, which is why we don't
>> really know what to do about it.
>> However when the following code in Kd_tree.h was turned public, it managed
>> to compile. It seems like a cheap and strange way to get it to work and I'm
>> not sure we'll ever know why it's so.
>> i.e.
>> // protected copy constructor
>> public:
>> Kd_tree(const Tree& tree)
>> : built_(tree.built_)
>> Thanks anyway. :)
> The copy constructor is not public because it's not implemented for
> public use.
> If you have a compilation error, it's because you are trying to copy a
> class containing a kd-tree (which is not possible). You should use
> something like a reference or a (shared) pointer to your tree instead
> (if it makes sense for your application).
> Sebastien
Kd_tree should really derive from boost::non_copyable. That would (at
least on gcc) produce clearer error messages. We might also use
Kd_tree(const Tree& tree) = deleted;
on compilers that support it. Although I doubt users that are not
familiar with the error message already will know what it means.
Philipp Moeller
GeometryFactory
- [cgal-discuss] Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, freckles, 03/26/2012
- Re: [cgal-discuss] Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, Philipp Moeller, 03/26/2012
- [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, freckles, 03/27/2012
- Re: [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, Sebastien Loriot (GeometryFactory), 03/27/2012
- Re: [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, Philipp Moeller, 03/27/2012
