[cgal-discuss] Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?
- To:
- Subject: [cgal-discuss] Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?
- Date: Mon, 26 Mar 2012 02:44:52 -0700 (PDT)
I am facing this problem with Orthogonal_k_neighbor_search::Tree, when even
using the same typedefs as the simple example on
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html
, I am unable to compile.
I get a "cannot access private member declared in class CGAL::Kd_tree"
compile error and this makes *no* sense at all, because it is clearly
declared public in the Kd_tree class.
Is there any way this could ever occur?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Kd-Tree-problem-cannot-access-Orthogonal-k-neighbor-search-Tree-as-it-is-private-tp4505262p4505262.html
- [cgal-discuss] Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, freckles, 03/26/2012
- Re: [cgal-discuss] Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, Philipp Moeller, 03/26/2012
- [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, freckles, 03/27/2012
- Re: [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, Sebastien Loriot (GeometryFactory), 03/27/2012
- Re: [cgal-discuss] Re: Kd Tree problem: cannot access Orthogonal_k_neighbor_search::Tree as it is private?, Philipp Moeller, 03/27/2012
