- To:
- Subject: [cgal-discuss] Kernel is not a class or namespace name
- Date: Fri, 6 Apr 2012 00:03:36 -0700 (PDT)
Hi all,
I use visual stidio 2005, and a install CGAL4.0 and the latest third
party softwares CMake, QtSDK and Boost. (I am not sure if I install them
correctly.) And I want to use width_simplex.cpp to compute the width of of a
3D points set. However, when I compile the given code without any
modification, errors occurs saying:
Homogeneous is not a member of CGAC
Width_3 is not a member of CGAC
simplex undeclared identifier
Thanks and Kind Regards
Daisy
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Kernel-is-not-a-class-or-namespace-name-tp4536827p4536827.html
- [cgal-discuss] Kernel is not a class or namespace name, daisy, 04/06/2012
- [cgal-discuss] Re: Kernel is not a class or namespace name, daisy, 04/06/2012
- Re: [cgal-discuss] Kernel is not a class or namespace name, Philipp Moeller, 04/06/2012
- [cgal-discuss] Re: Kernel is not a class or namespace name, daisy, 04/09/2012
- Re: [cgal-discuss] Re: Kernel is not a class or namespace name, Philipp Moeller, 04/09/2012
- Re: [cgal-discuss] Kernel is not a class or namespace name, Sebastien Loriot (GeometryFactory), 04/06/2012
