- To:
- Subject: Re: [cgal-discuss] Re: Kernel is not a class or namespace name
- Date: Mon, 09 Apr 2012 19:36:42 +0200
daisy
writes:
> Hi,
> I know that Visual Studio 2008 and 2010 are supported by CGAL4.0
> according to the Installation Manual
> , and the previous versions, such as CGAL3.4, support VS2005. So, this is
> the problem?
I don't know. Even if your code is broken for some other reason it is
unlikely that most CGAL packages would compile with VS2005.
> The higher version CGAL4.0 doesn's support VS2005?
Exactly.
> What about
> MinGW? It can make the CGAL4.0 support VS2005 or it shoud replace VS2005? I
> am a new to cgal, so I have so many questions.
MinGW provides a UNIX environment along with the common compiler
tool-chain for Windows boxes. This is orthogonal to CGAL. Either get
MinGW to replace VS2005 or get a newer version of VS. I wont post links
to the Express Version of Visual Studio, but your favorite search engine
should get you there.
HTH,
Philipp Moeller
- [cgal-discuss] Kernel is not a class or namespace name, daisy, 04/06/2012
- [cgal-discuss] Re: Kernel is not a class or namespace name, daisy, 04/06/2012
- Re: [cgal-discuss] Kernel is not a class or namespace name, Philipp Moeller, 04/06/2012
- [cgal-discuss] Re: Kernel is not a class or namespace name, daisy, 04/09/2012
- Re: [cgal-discuss] Re: Kernel is not a class or namespace name, Philipp Moeller, 04/09/2012
- Re: [cgal-discuss] Kernel is not a class or namespace name, Sebastien Loriot (GeometryFactory), 04/06/2012
