- To:
- Subject: Re: [cgal-discuss] Use refine_mesh on a point cloud
- Date: Wed, 11 Apr 2012 08:24:07 +0200
On 04/10/2012 07:26 PM, Francesc wrote:
I am trying to refine an already created mesh, in order to remove slivers.If you mesh does not fit inside a weighted Delaunay triangulation, there is no chance refine_mesh will work.
Essentially, I want the inscribed spheres to my tetrahedrons to be "big
enough".
I think that I should be able to use refine_mesh for this purpose, but I
want to use my already generated set of points as an input to this
algorithm. I am new to CGAL and I have been trying to achieve this without
success...
Is there any way that I can set up a MeshComplex_3InTriangulation_3 with my
point-cloud / mesh ? so that I can run the refine_mesh after that?
Will it be better to use a MeshDomainWithFeatures_3 and assume that my nodes
are features which should be represented? (that is not truthful or correct,
but it may do the trick).
Thank you,
What are the reasons which prevent you from using directly the 3D mesh generator of CGAL?
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Use-refine-mesh-on-a-point-cloud-tp4546365p4546365.html
- [cgal-discuss] Use refine_mesh on a point cloud, Francesc, 04/10/2012
- Re: [cgal-discuss] Use refine_mesh on a point cloud, Sebastien Loriot (GeometryFactory), 04/11/2012
- [cgal-discuss] Re: Use refine_mesh on a point cloud, Francesc, 04/11/2012
