- To: <>
- Subject: 答复: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
- Date: Wed, 11 Apr 2012 09:49:38 +0800
Hi Pedro, I am not sure what happened to you now. Once I created a MFC program, this program didn’t show its UI while The program was running. After I have applied windows update, the program works well even if now with depedecywalker the system can not find GPSVC.dll and IESHIMS.dll. My programming environment is Win7+vs2010. I think you can building a simple executable .exe which can show your questions and email it to me. Maybe in my computer it will work well. Regards, Yong Xiao. 发件人: Pedro Alexandre de Araújo Gomes Lapido Loureiro [mailto:] Hi Yong, I've followed your suggestion about using dependencywalker. Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module. The problems seem to be in: c:\windows\system32\SHLWAPI.DLL and c:\windows\system32\IEFRAME.DLL But these libraries are there. Regards, Pedro. Em 9 de abril de 2012 21:29, xiao yong <> escreveu: Hi, Pedro, In most cases, copy needed .dll to the same folder will solve this question. I think I cannot find the reason and solution without trying myself. But I recommend you to utilize dependency walker (http://www.dependencywalker.com/) to find out which dll is missing? Does copied dll match the missing dll? Hope this could help. Yong xiao. 发件人: Pedro Alexandre de Ara újo Gomes Lapido Loureiro [mailto:] Hi, xiao yong, thank you for your reply. I've copied this dll for the /debug folder. Now, another runtime error complains of boost_thread-vc100-mt-gd-1_47.dll is missing. Even copying this library for the same folder does not solve the issue... Any ideas? Regards. Pedro. Em 9 de abril de 2012 03:56, xiao yong <> escreveu: Perhaps you should add dll created by cgal to windows/system32. Or add the path of the folder of dlls to the environment variable ‘path’. Or for simplicity, you can copy these dlls to the same folder witch .exe file. Hope this could help. Edward 发件人: Pedro Alexandre de Araújo Gomes Lapido Loureiro [mailto:] Hello, when I try to execute the demos in CGAL 4.0, compiled with VS 10, there is a system error saying the library CGAL-vc100-mt-gd-4.0.dll was not found. The project was configured and generated with cmake - 2.8.7 in release mode. Would you have any suggestions? Regards, Pedro. |
- [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, Pedro Alexandre de Araújo Gomes Lapido Loureiro, 04/08/2012
- 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, xiao yong, 04/09/2012
- Re: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, Pedro Alexandre de Araújo Gomes Lapido Loureiro, 04/09/2012
- 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, xiao yong, 04/10/2012
- Re: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, Pedro Alexandre de Araújo Gomes Lapido Loureiro, 04/10/2012
- 答复: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, xiao yong, 04/11/2012
- Re: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, daisy, 04/13/2012
- Re: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, gwenaelle . marquant, 04/13/2012
