- To:
- Subject: [cgal-discuss] Problem using Straight Skeleton Algorithm
- Date: Sat, 14 Apr 2012 03:37:32 -0700 (PDT)
I am running SsPtr ptr = CGAL::create_interior_straight_skeleton_2(poly);
with the following polygon:
[x: 835, y: 274]
[x: 1008, y: 612]
[x: 835, y: 948]
[x: 835, y: 1188]
[x: 781, y: 1412]
[x: 782, y: 1410]
[x: 782, y: 1411]
[x: 586, y: 1454]
[x: 634, y: 1227]
[x: 634, y: -5]
[x: 584, y: -233]
[x: 796, y: -172]
[x: 835, y: 35]
[x: 835, y: 274]
But create_interior_straight_skeleton_2 produces an infinite loop.
If I remove the points
[x: 782, y: 1410]
[x: 782, y: 1411]
from the polygon, the algorithm works as expected.
Thanks
Sascha
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-using-Straight-Skeleton-Algorithm-tp4556961p4556961.html
- [cgal-discuss] Problem using Straight Skeleton Algorithm, man, 04/14/2012
- Re: [cgal-discuss] Problem using Straight Skeleton Algorithm, Sebastien Loriot (GeometryFactory), 04/18/2012
