cgal-discuss - [cgal-discuss] Re: How to use the examples of CGAL
  • To:
  • Subject: [cgal-discuss] Re: How to use the examples of CGAL
  • Date: Sat, 14 Apr 2012 03:55:03 -0700 (PDT)
After I add or modify some codes to the file *width_simplex.cpp*, the
example's output change with to my modification if I configure and generate
the examples again by Cmake. Because the file *width_simplex.exe *would not
update. I must build solution by vs2010, the *width_simplex.exe * will be
updated.Then, I launch the .exe file, the result changes with my
modification.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-use-the-examples-of-CGAL-tp4553639p4556983.html
