Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10
- To:
- Subject: Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10
- Date: Wed, 25 Apr 2012 11:44:11 +0200
Le mardi 24 avril 2012 20:45:05 stupormundi a écrit :
> I realized that cmake indicated that it DID find the libs:
> -- Found QGLViewer: /usr/lib/x86_64-linux-gnu/libqglviewer-qt4.so
> I then checked CMakeCache.txt and found these entries :
> //Path to a file.
> QGLVIEWER_INCLUDE_DIR:PATH=/usr/include
> //The QGLViewer library
> QGLVIEWER_LIBRARIES:FILEPATH=/usr/lib/x86_64-linux-gnu/libqglviewer-qt4.so
> //Path to a library.
> QGLVIEWER_LIBRARY_DEBUG:FILEPATH=QGLVIEWER_LIBRARY_DEBUG-NOTFOUND
> QGLVIEWER_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libqglviewer-qt
> 4.so
QGLviewer is indeed found, at least the release version, that can be used
also
in Debug builds (on Linux the distribution usually do not ship debug
versions,
but only the release version, plus separate debug symbols).
That is fine.
> and :
> //Path to a file.
> QT_QTOPENGL_INCLUDE_DIR:PATH=/usr/include/qt4/QtOpenGL
> //The Qt QTOPENGL library
> QT_QTOPENGL_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtOpenGL.so
> QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=QT_QTOPENGL_LIBRARY_DEBUG-NOTFOUND
> QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtOpenGL.s
> o
Same: QtOpenGL is found, and the library is is /usr/lib/x86_64-linux-gnu/.
> To compare, the complaint from make is :
> make[2]: *** No rule to make target `/usr/lib/libQtOpenGL.so', needed by
> `AABB_tree/AABB_demo'. Stop.
Really strange. Have you started the CMake configuration from an empty cache?
Could it be that libQtOpenGL.so was in /usr/lib/ in a previous version of
your
Linux distribution, and you have not cleared the CMake cache since?
Laurent Rineau, PhD
- [cgal-discuss] Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, stupormundi, 04/23/2012
- Re: [cgal-discuss] Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, Sebastien Loriot (GeometryFactory), 04/23/2012
- [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, stupormundi, 04/24/2012
- [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, stupormundi, 04/25/2012
- Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, Guillaume Damiand, 04/25/2012
- Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, Laurent Rineau (GeometryFactory), 04/25/2012
- Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, Guillaume Damiand, 04/24/2012
- [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, stupormundi, 04/28/2012
- [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, stupormundi, 04/29/2012
- Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, Guillaume Damiand, 04/30/2012
