cgal-discuss - [cgal-discuss] Re: where is QT_SCRIPT_LIB defined in ployhedron demo
  • To:
  • Subject: [cgal-discuss] Re: where is QT_SCRIPT_LIB defined in ployhedron demo
  • Date: Thu, 17 May 2012 08:04:49 -0700 (PDT)
Thanks to Andreas Fabri and Randall.
yes, these moc files indeed generate by the moc compiler of Qt.
I can see this in Camke file.
en.. the problem is I want to add headers and source files into QT Creator
manually to compile polyhedron demo.
thus, those moc files are missed.
In addition, I just used Camke to compile Polygon demo, the moc file can be
produced successfully;
The strange thing was I could't see the moc files while using Cmake to
Regards,
Xianyong Liu
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/where-is-QT-SCRIPT-LIB-defined-in-ployhedron-demo-tp4642922p4643085.html
