- To:
- Subject: Re: [cgal-discuss] Re: where is QT_SCRIPT_LIB defined in ployhedron demo
- Date: Thu, 17 May 2012 17:21:53 +0200
Hello Xianyong Liu,
The polyhedron demo not only needs Qt4 but also QGLViewer.
Did you install that already?
andreas
On 17/05/2012 17:04, ayongwust_sjtu wrote:
Thanks to Andreas Fabri and Randall.
yes, these moc files indeed generate by the moc compiler of Qt.
I can see this in Camke file.
en.. the problem is I want to add headers and source files into QT Creator
manually to compile polyhedron demo.
thus, those moc files are missed.
In addition, I just used Camke to compile Polygon demo, the moc file can be
produced successfully;
The strange thing was I could't see the moc files while using Cmake to
Regards,
Xianyong Liu
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/where-is-QT-SCRIPT-LIB-defined-in-ployhedron-demo-tp4642922p4643085.html
- [cgal-discuss] where is QT_SCRIPT_LIB defined in ployhedron demo, ayongwust_sjtu, 05/17/2012
- Re: [cgal-discuss] where is QT_SCRIPT_LIB defined in ployhedron demo, Laurent Rineau (GeometryFactory), 05/17/2012
- [cgal-discuss] Re: where is QT_SCRIPT_LIB defined in ployhedron demo, ayongwust_sjtu, 05/17/2012
- Re: [cgal-discuss] Re: where is QT_SCRIPT_LIB defined in ployhedron demo, Andreas Fabri, 05/17/2012
- Re: [cgal-discuss] Re: where is QT_SCRIPT_LIB defined in ployhedron demo, Randy Creasi, 05/17/2012
- [cgal-discuss] Re: where is QT_SCRIPT_LIB defined in ployhedron demo, ayongwust_sjtu, 05/18/2012
