- From: Marius Kintel <(005b7a4cd6%hidden_head%005b7a4cd6)marius(005b7a4cd6%hidden_at%005b7a4cd6)kintel.net(005b7a4cd6%hidden_end%005b7a4cd6)>
- To: (005b7a4cd6%hidden_head%005b7a4cd6)cgal-discuss(005b7a4cd6%hidden_at%005b7a4cd6)lists-sop.inria.fr(005b7a4cd6%hidden_end%005b7a4cd6)
- Subject: Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3
- Date: Wed, 30 May 2012 00:20:30 +0200
On May 29, 2012, at 23:50 PM, Joachim Reichel wrote:
> to test the basic rounding mode stuff you could try the attached test case.
Thanks for the tip!
I've run this on two computers (Mac OS X 10.6 and 10.7) and the two available
compilers for each computer.
As you can see from the output below, the only way to get an optimized build
to work is to use the plain gcc compiler, which is no longer available
starting with Mac OS X 10.7.
I guess that's bad news in terms of CGAL-compatibility for Mac OS X.
Ideas are welcome :)
Thanks,
-Marius
Error configurations:
10.6 gcc-4.2.1
c++ -O2 rounding_modes1.cpp -o rounding_modes1
10.6 llvm-gcc-4.2.1
llvm-g++ -O2 rounding_modes1.cpp -o rounding_modes1
llvm-g++ -O2 -frounding-math rounding_modes1.cpp -o rounding_modes1
10.7 llvm-gcc-4.2.1
10.7 clang-3.1
c++ -O2 -frounding-math rounding_modes1.cpp -o rounding_modes1
OK configurations:
10.6 gcc-4.2.1
c++ rounding_modes1.cpp -o rounding_modes1
c++ -frounding-math rounding_modes1.cpp -o rounding_modes1
10.6 llvm-gcc-4.2.1
llvm-g++ rounding_modes1.cpp -o rounding_modes1
llvm-g++ -frounding-math rounding_modes1.cpp -o rounding_modes1
10.7 llvm-gcc-4.2.1
10.7 clang-3.1
Error behavior:
fegetround() = FE_TONEAREST
fesetround (FE_TOWARDZERO)
fegetround() = FE_TOWARDZERO (ok)
fetestround() = FE_TONEAREST (error)
fesetround (FE_UPWARD)
fegetround() = FE_UPWARD (ok)
fesetround (FE_DOWNWARD)
fegetround() = FE_DOWNWARD (ok)
fesetround (FE_TONEAREST)
fegetround() = FE_TONEAREST (ok)
fetestround() = FE_TONEAREST (ok)
- [cgal-discuss] Crash with Nef_polyhedron_3, James Gregson, 05/28/2012
- [cgal-discuss] Re: Crash with Nef_polyhedron_3, kintel, 05/29/2012
- Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3, Sebastien Loriot (GeometryFactory), 05/29/2012
- Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3, Marius Kintel, 05/29/2012
- Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3, Joachim Reichel, 05/29/2012
- Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3, Marius Kintel, 05/30/2012
- Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3, Marc Glisse, 05/30/2012
