cgal-discuss - Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3
  • To:
  • Subject: Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3
  • Date: Wed, 30 May 2012 10:58:34 +0200
On May 30, 2012, at 07:59 AM, Marc Glisse wrote:
> Anything based on llvm is broken, but we have code in CGAL to work around
> that (at least in recent versions).
>> to test the basic rounding mode stuff you could try the attached test case.
> That doesn't account for our workarounds, you really want to test
> Interval_nt. And there is already a run-time test checking that rounding
> works, which gets executed by every CGAL program.
OK, makes sense. That run-time check appears to pass on all platforms, as
most CGAL programs I've run actually runs without problem. My issues are (for
me) limited to Nef_polyhedron_3.
Do you think this is just a bug in CGAL which happen to trigger on some llvm
compilers?
Is there any way I can report this properly, or provide enough data so that
the right people can pinpoint and take a look at this?
Cheers,
-Marius
