Re: [cgal-discuss] CGAL::Assertion_exception -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
- To:
- Cc:
- Subject: Re: [cgal-discuss] CGAL::Assertion_exception -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
- Date: Sun, 17 Jun 2012 01:51:07 +0200
Vero
writes:
> Hi,
> I hope you can please help me with this.
> I just compiled CGAL 3.9 in Scientific Linux, with
> gcc (GCC) 4.4.6 20110731 (Red Hat 4.4.6-3).
> Linux x86_64
> I compiled CGAL following this steps:
> cmake -DCMAKE_INSTALL_PREFIX=/data/.../CGAL-3.9/build
> -DCGAL_CXX_FLAGS=-frounding-math .
> make VERBOSE=1
> make install
> The compilation messages indicate the use of -frounding-math during
> the process. (I even tried adding it to the compilation of my own
> program)
> I have the same version in Ubuntu 10, working perfectly well with the
> same code, but my program fails in this other machine. When trying to
> run any program I get:
> bash-4.1$ ./tests/CGALTest
> terminate called after throwing an instance of 'CGAL::Assertion_exception'
> what(): CGAL ERROR: assertion violation!
> Expr: -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
> File: /data/.../CGAL-3.9/build/include/CGAL/Interval_nt.h
> Line: 159
> Explanation: Wrong rounding: did you forget the -frounding-math
> option if you use GCC (or -fp-model strict for Intel)?
> Aborted
> ... snip ...
> Compiled with:
> ## CGALTest
> CGALTEST = CGALTest
> $(CGALTEST)_HPP = include/massspring/Mass_Spring_Graph.hpp
> include/massspring/Mass_Spring_mesh_face_base.hpp
> include/massspring/Mass_Spring_vertex_base.hpp
> $(CGALTEST) : tests/src/$(CGALTEST).cpp $($(CGALTEST)_HPP)
> $(CXX) $(CPPFLAGS) tests/src/$(CGALTEST).cpp -o $(CGALTEST) -Iinclude
> $(CGALREQS)
> mv $(CGALTEST) tests/
> Thank you for your attention
Your executable needs to be compiled with -frounding-math as well. Just
compiling the CGAL libraries isn't enough as most of our code resides in
headers.
$(CXX) $(CPPFLAGS) -frounding-math tests/src/$(CGALTEST).cpp -o
should do the trick, but you probably want to integrate this a little
better into your build-system.
- [cgal-discuss] CGAL::Assertion_exception -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1), Vero, 06/16/2012
- [cgal-discuss] segment intersection outside bounds, W Randolph Franklin, 06/18/2012
- Re: [cgal-discuss] segment intersection outside bounds, Sebastien Loriot (GeometryFactory), 06/19/2012
- Re: [cgal-discuss] segment intersection outside bounds, W Randolph Franklin, 06/20/2012
- Re: [cgal-discuss] segment intersection outside bounds, Sebastien Loriot (GeometryFactory), 06/21/2012
- Re: [cgal-discuss] CGAL::Assertion_exception -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1), Philipp Moeller, 06/17/2012
