cgal-discuss - Re: [cgal-discuss] segment intersection outside bounds
  • To:
  • Subject: Re: [cgal-discuss] segment intersection outside bounds
  • Date: Tue, 19 Jun 2012 08:18:07 +0200
Read these FAQ entries:
http://www.cgal.org/FAQ.html#predicates_vs_constructions
http://www.cgal.org/FAQ.html#inexact_NT
If you replace Exact_predicates_inexact_constructions_kernel by
Exact_predicates_exact_constructions_kernel your error won't appear.
Sebastien.
On 06/18/2012 11:52 PM, W Randolph Franklin wrote:
Hi,
The following program fragment seems to show that the intersection of 2
segments can be outside their bounds. I'm still learning, so the
mistake is probably mine, but I can't find it. Help?
FYI, error.C was extracted from a much larger program and dataset.
Note that I'm using Exact_predicates_inexact_constructions_kernel and
the erroneous result was computed with a chain of Segment_2,
intersection, compare_x.
I compiled it this:
/usr/bin/g++-4.7 -O3 -frounding-math error.C -lCGAL -lmpfr -lgmp -o
error
My system is this:
Linux host 3.2.0-25-generic #40-Ubuntu SMP Wed May 23 20:30:51 UTC 2012
x86_64 x86_64 x86_64 GNU/Linux
Thanks.
// Time-stamp:</wrf/c/overprop/error.C, Mon, 18 Jun 2012, 17:41:12 EDT,
http://wrfranklin.org/>
#include<iomanip>
#include<iostream>
using namespace std;
#include<CGAL/Exact_predicates_inexact_constructions_kernel.h>
#include<CGAL/intersections.h>
#include<CGAL/Object.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
using CGAL::Object;
using CGAL::compare_x;
using CGAL::compare_y;
using CGAL::object_cast;
// Print an expression's name then its value, possible followed by a
// comma or endl. Ex: cout<< PRINTC(x)<< PRINTN(y);
#define PRINT(arg) #arg "="<< (arg)
#define PRINTC(arg) #arg "="<< (arg)<< ","
#define PRINTN(arg) #arg "="<< (arg)<< endl
int main() {
cout<< "Intersection of 2 segments is outside their bounds."<< endl;
K::Point_2 v0(63.6421, 2067.410);
K::Point_2 v1(62.7046, 2071.750);
K::Point_2 w0(62.7046, 2071.750);
K::Point_2 w1(59.8669, 2066.980);
Object obj = CGAL::intersection(K::Segment_2(v0,v1), K::Segment_2(w0,w1));
if (const K::Point_2 *xsect = object_cast<K::Point_2>(&obj)) {
cout<< "Intersection found. "<< PRINTC(v0)<< PRINTN(v1)<<
PRINTC(w0)<< PRINTN(w1)<< PRINTN(*xsect);
if ((compare_x(*xsect,v0)*compare_x(*xsect,v1)>0) ||
(compare_y(*xsect,v0)*compare_y(*xsect,v1)>0) ||
(compare_x(*xsect,w0)*compare_x(*xsect,w1)>0) ||
(compare_y(*xsect,w0)*compare_y(*xsect,w1)>0)) {
cout<< "\nERROR: intersection is not within bounds of edges."<<
endl;
cout<< PRINTN(compare_x(*xsect,v0));
cout<< PRINTN(compare_x(*xsect,v1));
cout<< PRINTN(compare_y(*xsect,v0));
cout<< PRINTN(compare_y(*xsect,v1));
cout<< PRINTC(compare_x(*xsect,w0))<< " WRONG, should be 0"<< endl;
cout<< PRINTN(compare_x(*xsect,w1));
cout<< PRINTN(compare_y(*xsect,w0));
cout<< PRINTN(compare_y(*xsect,w1));
cout<< scientific<< PRINTN(xsect->x()-w0.x())<< endl;
Output:
Intersection found. v0=63.6421 2067.41, v1=62.7046 2071.75
w0=62.7046 2071.75, w1=59.8669 2066.98
*xsect=62.7046 2071.75
compare_x(*xsect,v0)=-1
compare_x(*xsect,v1)=1
compare_y(*xsect,v0)=1
compare_y(*xsect,v1)=0
compare_x(*xsect,w0)=1, WRONG, should be 0
compare_x(*xsect,w1)=1
compare_y(*xsect,w0)=0
compare_y(*xsect,w1)=1
xsect->x()-w0.x()=7.105427e-15
W. Randolph Franklin, Professor
ECSE Dept., 6026 JEC,
Rensselaer Polytechnic Inst,
110 8th St,
Troy NY, 12180 USA
(most reliable address) or
or
+1 (518) 276-6077
